HI!!!
this is very urgent, all morning ive been working on overclocking my 3770k on a maximus V Formula which is now under a custom loop and so I decided to go ahead with it
Ive been using an overclocking guide on the ROG forums for my exact same setup less the custom wc loop with an h100i...Anyways I went a little to low on the voltage for the clock I was trying to pull, I was trying to get 4.7GHz and the voltage that was to low was 1.25V. Ok, now i was expecting a crash at some point, then I would have to go back up on the voltage to get my most stable clock with lowest volts. So i went back into the UEFI and but the voltage back up to 2.8v and ramped down to 4.5GHz (reallly cause I was just scared) which it was stable at. I hit F10, save, and reboot windows, but when i get back into windows ITS STILL IS AT 1.25V AND 4.7GHz! I was so stressed I went back into the UEFI and reset all the stuff to default, (by hitting F5) which it should be ramed down to 3.9GHz, yet whenever I load windows all my voltages and multiplyers are still to high and too low which causes my PC to crash whenever I play BF3 or run Prime 95.
Please I dont know how to fix this problem and I need sugesstions
          Thank You.
                                     Nedyahiske
wtf, 2.5v? o.O
did you try hitting the cmos reset switch on the mobo?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Heya,
Are you sure about the voltages you're using. They're extremely high for the CPU. I have my 3770K at 1.35v and stable at 4.5GHz. You will defo kill your CPU if you pump that much voltage into it
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
How did you get that voltage there without burning it out?
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
no, hope thas not to high, or theres something seriously wrong with my rig, I was under conception that that was low
well, normally you have around 1.3-1.4v on the vcore.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
OH **** IM SO SRY I MEANT 1.25V not 2.5 DERP
rofl well if you're stable at 4.7GHz with 1.25v then that should be fine, what are your temperatures?
@Nedyahiske,no.....2.5v is extremely high.
I wouldn't even go to 1.5v without LN2.
1.25v is perfectly fine.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
What is LN2?
No thats the thing IM NOT stable at 1.25 V 4.7GHz, but I cant change back
Take the multiplier down a few notches
liquid nitrogen
I makes sense lol
I CANT CHANGE THE MULTIPLIER,, EVERYTHING I DO IN BIOS IS NOT REFLECTED IN WINDOWS!!! I EVEN TRIED DEFAULT AND IT DIDNT CHANGE
Download a utility from Asus and change it in Windows, MSI has one called Control Centre, I'm sure Asus has one that is similar
my CPU-z still tells me 4.7GHz when It says in bios the multiplier for ALL cores is set to 39 which is the default, I followed the guide from ASUS ROG excatly everything that needs to be is set to manual
I'd contact them for advice since you've followed their guide, other than that I don't know what to suggest, but I'd try and change the voltage/multiplier in Windows and see if that has any effect.
Why don't you just do the USB BIOS flashback thing that Asus motherboards support and start again? Safe and simple.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
did i just read 2.8 volts? and update the bios , 1.27 is stable for my 3770k @ 4.7 and thry to up vrm settings so it can be more stable
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
