Drain valve
Solved by ForsakenLive,
Get the Bitspower mini tap, the end is threaded and you can use a plug on it for extra safety (same plugs there are on radiators, for the ports you are not using).
kerriya ·
Posted in Cases and Mods3 -
octester ·
Posted in Troubleshooting5 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
play_circle_filled
Latest From ShortCircuit:
