https://linustechtips.com/topic/282885-gpu-help/#findComment-3840131
Cheers, just wanted to make sure before i pay all that money
Here's one for your region.
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16814487068&cm_re=GTX_980-_-14-487-068-_-Product
https://linustechtips.com/topic/282885-gpu-help/#findComment-3840164
Oh haha, i was replying as you linked it
It just sold out. The one you linked is the same one. It supports water cooling.
https://linustechtips.com/topic/282885-gpu-help/#findComment-3840179
