I have been working on my system getting ready to install my 980 and have finally gotten my fan curves down to where I cant hear a single fan with all of my panels off. Now over the last few days I have noticed a very annoying fan baring sound starting to come from my PC, I now know its the fan on my CX600W :( (I have flipped the fan facing up and the noise is still present). I am really disappointed with the CX600W and will be returning it and getting a better PSU.
Now I have been looking at my options and have come up with the Corsair RM650. Now I'm very concerned that this PSU will have similar problems. I know it wont run the fan below a certain power usage but I'm really skeptical that it will be much better than the CX600W.
What are your thoughts are there any other PSU options I should conciser? (I don't have much room for cables so the flat ones on Corsair PSU's have really got me on a leash)
Quantum Chaos: i7 6850K | 2x Strix 1080Ti SLI | MSI X99 SLI Krait | 32GB Corsair Vengeance LPX | Samsung 970 EVO 500GB | 3TB WD Red RAID 1
https://linustechtips.com/topic/282559-corsair-cx600-issues/
where you will be buying from the PSU and the max budget?
EVGA 650 G2 will be way better than the RM
or my personal choice is the CoolerMaster VSM650 which is semi modular
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836031
I have no room for cables and I really want it to be silent I would prefer to not go above 150$. I usually purchase from Amazon.
I must stress the no room for cables I can no longer fit a conventional 24 Pin connector in my system.
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836063
To my knowledge there is no 650w g2. At minimum a 750w. Which is a good candidate.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836069
the VSM650 isnt that expensive as you think and it semi modular and the mobo power cables are long enough
http://pcpartpicker.com/part/cooler-master-power-supply-rs650amaag1s1
yea i think it was the G1 version
and yea the 750 is damn good PSU
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836081
Mhm. There is certainly a 650w evga nex which is okay, but nowhere near on the same level as an evga 750w g2. The g2 and p2 series of power supplies has nothing of the same quality to my knowledge, save maybe the corsair axi series which is almost twice the price.
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836103
I do like the EVGA PSU but they are not sold in Asia countries
so I only use CoolerMaster
and the Corsair AXi are overpriced here
imagine paying the price of a 280X for the 1500Watts model
I still have a monster PSU that I have yet to use it
CoolerMaster Silent Pro Hybrid 1300 watts Gold and it has it own fan controller bundled
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836118
Length is something I really need to avoid Its a 7 inch run from the PSU to MB. and I only have a 4"x4"x6" box to hold the bulk of all excess cables. This is why Im looking for something like the corsair style cables.
I was looking at the EVGA SuperNOVA PSU's but I would most likely have to shorten the 6 pin PCI-E connectors because of there bulk (This is something I don't want to do)
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836123
Corsair axi models are overpriced everywhere, which is why I will NEVER recommend them. Like I said evga power supplies of similiar quality are almost half the price here. I don't suspect it will be worse abroad.
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836137
custom sleeving?
a bit risky but if you are careful it may work and look better
I only see Corsair, Seasonic, CoolerMaster, ThermalTake,Silverstone and FSP
Among the brands, only the CoolerMaster are the sweetspot in terms of price to performance.
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836163
custom sleeving?
Before the g2 series came out, I almost went with a coolermaster power supply. So in my opinion I would do that same.
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836182
Yea if only EVGA distributes it products to the Asia market
I hardly see any EVGA GPUs let alone the PSUs and mobos
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836188
custom sleeving?
I was considering this.
Do you have any specific gripes on the Corsair RM Series?
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836195
the capactiors in the RM are known to fail prematurelly
they were using either Taiwan or China made caps
https://linustechtips.com/topic/282559-corsair-cx600-issues/#findComment-3836207
