So I Have Windows 10 build 9879
And in C\:: I have a folder called  "AX6HPBC85FMOVZ38WNG7D5E3STJ8KLU5IQRY21"
inside it has lots of files like "zzzz........zzzzzzzzzz" "zzzzzzzzzz....zzzz" etc   Imgur link:http://imgur.com/UV4y9kz
I have scanned my system and the file and no viruses/Malware.
It contains 123,065 files and 491 folders and take sup 5.04MBs, Size on Disk says 0 bytes
Also it looks like the only files are RAR and ZZ  ...
Its a sha1 coded file name. Its a Registry Hash apparently to google.
Info on that Hash below. And I don't have a Intel chip or 32 bit OS.
http://totalhash.com/analysis/aebd2b58afe221372e6d573edd0bf5b3fb9ebe4a  (Only results that show up when searching AX6HPBC85FMOVZ38WNG7D5E3STJ8KLU5IQRY21)
http://totalhash.com/analysis/aebd2b58afe221372e6d573edd0bf5b3fb9ebe4a  New link (same as before lol)
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/281900-urm-help-maybe-idk/
There's a troll sleeping in your C drive!
I have no clue what that is, but it looks like it could be corruption of some sort. Don't quote me!
EDIT: The hash link doesn't seem to work.
Added some info just google AX6HPBC85FMOVZ38WNG7D5E3STJ8KLU5IQRY21 and the hash thing will show up
Think i will delete it but i want to know what it is..
https://linustechtips.com/topic/281900-urm-help-maybe-idk/#findComment-3827844
Okay. You might want to take a backup, just to be safe.
Sig under construction.
https://linustechtips.com/topic/281900-urm-help-maybe-idk/#findComment-3827854
Trolls sleeping, i guess so.. Since the file type is ZZ
EDIT http://imgur.com/Qxfr0X6
https://linustechtips.com/topic/281900-urm-help-maybe-idk/#findComment-3827857
