More and cleaner power. Better for overclocking. 8+2 is better.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/281874-phase-power/#findComment-3827411
It really comes down to having cleaner power, more stable voltage, and less stress on the transistors(the transistors that convert the voltages).
https://linustechtips.com/topic/281874-phase-power/#findComment-3827423
Thank you guys :D
I think it's really irrelevant at this point when most of the overclocking components are now on the chip instead of the motherboard. Most of the stuff now is just for pure marketing, at least for the LGA1150 platform, but if you're on other sockets & AMD yeah it would deliver power with more stability.
https://linustechtips.com/topic/281874-phase-power/#findComment-3827552
So, I was browsing a lot of motherboards lately, and what I see are the "Phase Power" 4+2 or 8+2 blah blah. what does it really do?
it depends whether they are true phases or just doublers
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/281874-phase-power/#findComment-3827667
Phase power has to do with VRM(Voltage Regulator Module), which helps delivering cleaner power to the CPU, for better OC results. Cleaner power means that the voltage will not fluctuate much from the value you set in the BIOS tweaker, therefore causing instability.
For Intel, as it is right now, this VRM circuit seems to be integrated in the CPU, so the results are 90% dependant on the chip.
For AMD, on the other hand, the modulation is stil done on the motherboard, so that's why for AMD (FX CPUs mainly) you need a strong 8+2 phase motherboard, if you want to overclock.
MARS_PROJECT V2 --- RYZEN RIG
 CPU: R5 1600 @3.7GHz 1.27V | Cooler: Corsair H80i Stock Fans@900RPM | Motherboard: Gigabyte AB350 Gaming 3 | RAM: 8GB DDR4 2933MHz(Vengeance LPX) | GPU: MSI Radeon R9 380 Gaming 4G | Sound Card: Creative SB Z | HDD: 500GB WD Green + 1TB WD Blue | SSD: Samsung 860EVO 250GB  + AMD R3 120GB | PSU: Super Flower Leadex Gold 750W 80+Gold(fully modular) | Case: NZXT  H440 2015   | Display: Dell P2314H | Keyboard: Redragon Yama | Mouse: Logitech G Pro | Headphones: Sennheiser HD-569
https://linustechtips.com/topic/281874-phase-power/#findComment-3827789
So if I have an AMD FX-6300 (not gonna overclock it), should I buy 8+2 or 4+2 so forth?
8+2
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/281874-phase-power/#findComment-3828885
