AMD VSR Problems
Go to solution Solved by ZetZet,
So ive been wanting to use AMD's new VSR in the Omega drivers, i enabled it, i can change my resolution from 1080 to 1440 just fine, except when i do it does not scale properly. It leaves black bars on the top and bottom like im watching a movie in "widescreen" mode or something. I tried to go into ccc to change the overscan settings, but Overscan is completely gone from ccc. Check image to see.
Does anyone know what the deal here is? Why is overscan gone? Why does it not scale properly? The black bars happen at desktop and in game
https://linustechtips.com/topic/281866-amd-vsr-problems/
https://linustechtips.com/topic/281866-amd-vsr-problems/#findComment-3827262
Wait, what's the resolution of your monitor?
edit: short attention span.
What does the utility say your resolution is?
1920x1080, 75 hz (Moniter is actually 60hz)
What do you mean? This is a guide to configuring GPU-Scaling, i already have it enabled
https://linustechtips.com/topic/281866-amd-vsr-problems/#findComment-3827334
and it still doesnt fill the screen?
https://linustechtips.com/topic/281866-amd-vsr-problems/#findComment-3827342
Ok apparently going into ccc and changing from "Scale image to full panel size" to "Maintain Aspect Ratio" and then switching back fixed everything :/ Thanks for all the help :D
https://linustechtips.com/topic/281866-amd-vsr-problems/#findComment-3832818
