... you can get a molex to 3 pin fan adapter anywhere for like 3$
http://www.ncix.ca/products/?sku=31670&vpn=CB-3M4M&manufacture=Works
you can get a fancy bitfenix alchemy molex to 3 fan adapter (with or without resistance (for lower fan speed/noise))
http://www.ncix.ca/products/?sku=62204&vpn=BFA-MSC-M33F12VKK-RP&manufacture=BitFenix
if you want a fan controller, look for fan controller on ncix.com
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37071
I dont want to plug them all into my power supply cause of noise
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37100
You could also get a splitter cable to plug more fans into the two connectors on your motherboard.
Such as:
NCIX (CA)'s Splitter: http://www.ncix.com/products/?sku=56217&vpn=TX3SPLITTER&manufacture=Startech.com
check your fan starting amp tho, too many fan on 1 motherboard header could burn it up.
BTW that cable is a molex splitter, it only transmit pwm signal from the mobo header,
so that is risk free for your motherboard but useless on 3 pin fans
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37118
Is there one like the Phantom 630? It looks pretty good cause you can hide all you cables at the back
are you looking for a fan splitter or a case?
You can probably hide the wires in your case too if that is what you ask.
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37120
Such as:
The idea was to show that these adapters exist. Plus what is the problem with the one I supplied it is getting power from molex and getting PWM information from the motherboard. You only loose out on controlling the fans individually.
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37124
Such as:
I just meant to point out that this splitter might not be what he wants if he has no 4 pin fans, or not to daisy chain multiple 3 pin fan splitter off 1 header.
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37128
Such as:
Na it is ok it didn t sound rude, i just wanted to clarify what I meant.
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37157
If you are looking for some special type of splitter, then you might have to search diffirent stores for it. Basic 1-2/3 splitters come with some cabling since they are cheap to make.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37404
I think I understand what you're looking for, but I have the feeling that chip in the back of the Phantom is actually the whole fan controller array.
The closest thing I can find is the Cooler Master Wind Rider, which is kind of the whole setup integrated in to one box; it looks like it's pretty tiny, so you may well be able to keep it out of sight (or maybe mod it if you're adventurous.)
https://linustechtips.com/topic/2815-need-more-fan-headers/#findComment-37470
