$200 is not even close to enough for a custom loop, like not even close
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/281421-i-need-help/#findComment-3820720
What are you looking to cool ? cpu ? gpu ? What size rad ? what's your case ?
I am going to use the Pentium anniversary edition. Will not be cooling my GPU and my case is the NZXT Guardian 921 RB and a 120 or 140 mm rad
GPU? Case? etc. so we know what will fit.
I am going to use the Pentium anniversary edition. Will not be cooling my GPU and my case is the NZXT Guardian 921 RB and a 120 or 140 mm raditor
I know I can get a custom loop for $200, I have already priced one out for $200 but I have never looked for these types of parts and just wanted some help.
https://linustechtips.com/topic/281421-i-need-help/#findComment-3820757
IMHO, i don't think you wont be-able to set up any watercooling. It's doesn't show and rad support on the NZXT website, but if you are really gonna try. Get a Single 120mm All in one unit. Like a H140-X. You can expand it in the future adding more rads and or more GPU blocks.
"Audiophilia... when you start to hear voices in your head."
https://linustechtips.com/topic/281421-i-need-help/#findComment-3820813
I want to see your parts then because good WC components cost tons
https://linustechtips.com/topic/281421-i-need-help/#findComment-3820826
I dont want an all in one. I want to build it my self
https://linustechtips.com/topic/281421-i-need-help/#findComment-3820847
I think you should either get a cheaper air cooling rad now and save the money to get custom water cooling later or go all out on an aio because with $200 i think its near impossible to get a good and durable custom water cooling loop for anything
| --- My Stuff --- |
Computer: Apple Late-2008 Macbook Pro ; -Haguro- build: http://linustechtips.com/main/topic/296613-wip-project-haguro-x99-hackintosh-workstation/|
Mobile Devices: Apple 32GB 1st gen Ipad Mini ; Apple 16GB Iphone 5s ; Apple Ipod Classic 80Gb 5th Gen ; Apple Ipod Classic 120Gb 6th Gen ; Apple Ipod Classic 160Gb 7th Gen ; Apple Ipod Nano 16Gb 6th Gen
https://linustechtips.com/topic/281421-i-need-help/#findComment-3820966
I don't really see much point in this i think it would be wiser to spend the money on a new cpu instead of custom water cooling but that's just my opinion.
^this. A Pentium can often even be OC'ed on the stock cooler, let alone a mid-level air cooler.
And like @ArchAngel 1994 pointed out, $200 will likely not provide you a custom loop with both good quality and good performance (which IMHO is what people should look for if they decide to go for water cooling).
So, would you mind posting the components you chose for that $200 loop?
[Main rig "ToXxXiC":]
CPU: Intel Core i7-4790K | MB: ASUS Maximus VII Formula | RAM: G.Skill TridentX 32GB 2400MHz (DDR-3) | GPU: EVGA GTX980 Hydro Copper | Storage: Samsung 850 Pro 256GB SSD + Samsung 850 EVO 1TB SSD (+NAS) | Sound: OnBoard | PSU: XFX Black Edition Pro 1050W 80+ Gold | Case: Cooler Master Cosmos II | Cooling: Full Custom Watercooling Loop (CPU+GPU+MB) | OS: Windows 7 Professional (64-Bit)
https://linustechtips.com/topic/281421-i-need-help/#findComment-3821965
$200 for new parts is tough and retain quality and trouble-free functions.
cpu block $50
radiator $50
tubing $20
fittings $15
reservoir $35
pump $75 (DDC or D5, others are a swing in the dark)
fans $20
avoid eBay "import" kits as they are not spec'd, guaranteed, of have any quality.
as asked, list your "kit" and let us help you get the best for your money and then
you make that determination if it is feasible with what you have.
https://linustechtips.com/topic/281421-i-need-help/#findComment-3822548
I want to make my first custom watercooling loop. I have a $200 budget for all of the parts. I have a LGA 1150 socket
This is as cheap as i could find. Bit over your budget but would be worth the extra $$$
    EK-KIT L120
    Incl. 22% VAT: $ 222.12
    stock_red.pngNo stock!
    Qty: Add to Cart
    Add to Wishlist
    Add to Compare
http://www.ekwb.com/shop/kits-cases/kits/ek-kit-l120.html
OR THIS
xspcrays_ss.jpg XSPC RayStorm CPU Waterblock for Intel  In stock $69.00  button_update_cart.gif$69.00 btn_x.gifXSPC-EX240s.jpg XSPC EX240 Radiator  In stock $49.00  button_update_cart.gif$49.00 btn_x.gif5060175583741s.jpg XSPC FLX Tubing Clear UV 1/2ID 3/4OD 2m  In stock $15.00  button_update_cart.gif$15.00 btn_x.gif5060175581815_s.jpg XSPC G1/4 Chrome 1/2 Compression Fitting  In stock $5.00  button_update_cart.gif$40.00 btn_x.gifXSPC-EC6-UVBLUE-thumb.jpg XSPC EC6 Liquid Cooling Coolant UV Blue  In stock $19.00  button_update_cart.gif$19.00 btn_x.gif5060175585691-thumb.jpg XSPC X2O 420 Single Bayres/Pump Combo  In stock $69.00  button_update_cart.gif$69.00 btn_x.gif5060175581938s.jpg XSPC 120mm Xinruilian Fan 1650RPM  In stock $9.00  button_update_cart.gif$18.00 btn_x.gif
Sub-Total: $279.00
https://linustechtips.com/topic/281421-i-need-help/#findComment-3827113
This might appear harsh but don't waste your time.
For what you're intending to do you'll spend a lot of money and get no improvement over a D14\15 if anything it will be noisier and you'll have increased your maintenance overhead. A single 120\140 in a custom loop with the associated components would be a waste of your money.
Buy a case more suitable for water cooling and a top quality air cooler and then start saving.
https://linustechtips.com/topic/281421-i-need-help/#findComment-3828813
