Power Supply Question/Problems
By
Guest
in Power Supplies
in Power Supplies
Solved by vlkn´,
Its just there is another one of those things in the PSU and the yellow plastic isn't crumpled silghtly and doesn't have the brown stuff on it.
If you´re not sure if you want to use this psu, get another one.
Psu´s are cheap these days. And this one can be used as replacement or for a new pc project.
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
1
play_circle_filled
Latest From ShortCircuit:
