I am doing a custom water loop for the first time in my upcoming build. I plan on using the CM Storm Stryker case for this new setup. I did tons of research and finally found all of the materials I would need for this setup. Now I just need a little insight on the parts I gathered for this setup. I will only be cooling my CPU for now but I plan on watercooling my GPU in the future. Any recommendations would be great.
Water Blocks:
http://www.swiftech.com/ApogeeXL.aspx
http://www.swiftech.com/KOMODO-NV-GTX9.aspx
Pump:
http://www.swiftech.com/mcp655.aspx
Reservoir:
http://www.frozenqshop.com/lf-reaction-dual-bay-reservoir/
http://www.frozenqshop.com/lf-reaction-250mm-cylinder-reservoir/
Tubing:
http://www.frozencpu.com/products/18773/ex-tub-1764/XSPC_FLX_Premium_Grade_PVC_Tubing_-_12_ID_34OD_-_2_Meter_65_Feet_Retail_Pack_-_Clear_UV_Blue.html?tl=c99s1614b49
Coolant:
http://www.xoxide.com/mayhem-auroranebulabluecoolantconcentrate-250ml.html
http://www.frozencpu.com/products/24286/ex-liq-386/Mayhems_Aurora_2_Coolant_Premix_-_1L_-_Nebula_Blue_.html?tl=g30c337s1809
http://www.xs-pc.com/coolant/ecx-ultra-concentrate-coolant-uv-blue
Fittings:
http://www.bitspower.com/html/product/pro_show.aspx?num=81092337&kind2=51
http://www.frozencpu.com/products/8099/ex-tub-423/Bitspower_G14_Thread_12_ID_x_34_OD_Compression_Fitting_-_Silver_BP-CPF-CC5.html?tl=c409s1609b145
http://www.frozencpu.com/products/11104/ex-tub-698/Bitspower_G14_Thread_12_ID_x_34_OD_Rotary_Compression_Fitting_-_Silver_BP-RCPF-CC5V2.html?tl=c409s1609b145
Fans:
http://www.amazon.com/dp/B00L64O63G/?tag=pcpapi-20
Radiator:
http://www.amazon.com/Alphacool-NexXxoS-Monsta-Radiator-120mm/dp/B007R798IY/ref=sr_1_17?ie=UTF8&qid=1415001681&sr=8-17&keywords=240mm+radiator
http://www.frozencpu.com/products/16236/ex-rad-410/Alphacool_NexXxoS_Monsta_Dual_120mm_Radiator_-_80mm_Thick.html
Thermal Compound:
http://www.newegg.com/Product/Product.aspx?Item=35-100-007
http://www.amazon.com/Noctua-NT-H1-Thermal-Compound-Retail/dp/B002CQU14A/ref=pd_sim_pc_71?ie=UTF8&refRID=1N60MSHVT1V7J2F1EDDD
https://linustechtips.com/topic/281200-first-time-water-cooling/
Agreed, rather go with distilled water and get color tubing
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
https://linustechtips.com/topic/281200-first-time-water-cooling/#findComment-3818062
I would use blue tubing and I wouldn't add dye in my coolant imo.
Anything else is should change. I did hear that the colored coolant stains your waterblock I just wanted the eye candy  ;)xD
https://linustechtips.com/topic/281200-first-time-water-cooling/#findComment-3818752
