I come here bearing but just one question. What is the best thermal interface material that we can get our hands on that wont destroy your cpu and/or heatsink? Looking at you liquid ultra... I do not care about price as long as it works beyond expectations.
Currently looking at GELID GC-Extreme but was wondering what you guys recommend.
I currently have arctic silver 5 but looking around, I am seeing that is is becoming a bit out dated.
CPU: Intel i7-8700k 5GHz @ 1.35v | Cooling: EK Predator 360 | MotherBoard: ASUS z370-E | RAM: G.Skill Ripjaws V 32gb 3200MHz (4 x 8GB) | GPU: ASUS GTX 1080 TI OC
Case: Rosewill Blackhawk Ultra Modded side panel | SSD: Samsung 512gb 960 Pro | HDDS: 3TB Segate 7200rpm / 4TB HGST 7200rpm | PSU: EVGA G3 1000w | Display:ASUS VG248QE 24" / HP 25" 2511x / SAMSUNG 35" TV
Ex HDD: 3TB WD MyBook USB 3.0 | Keyboard: Rosewill MX Blue / Corsair K70 Red | Mouse: Logitech G602 | OS: Windows 10 64-bit Home Premium
https://linustechtips.com/topic/280569-cpu-thermal-compound/
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809456
paste is paste, it doesnt make sense.
Something like the Noctua NT-1 paste is fine.
You're joking right ?
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809504
No im exaly damm serious.
like i said above over expensive stuff like artic silver and what not, is just marketing blalala
It doesnt make much sense.
There are only a few pasts that are exaly horrible, But Noctua NT-H1 is totaly fine.
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809524
I don't think $6 is overly expensive but I guess it's different for some people.  It does drop temps a few degrees, and that can mean the difference between a 4.4ghz overclock and a 4.6ghz or higher overclock.  While not important to all, some people would like to have the extra .1ghz or so.
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809545
Usually what comes with the heatsink is fine, but I personally use arctic mx-5 on my build.  Dropped temps a few degrees compared to the compound on my x61 cooler.
problem with pre aplied paste is that its spackled over the coolers surface.
So there will be airbubbles as soon as you push the heatsink down.
Thats why the credid card spreading method is so terrible.
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809564
It depends on the use, for most cases the pre-applied is fine.  But for everyone else you want something better.  As for the credit card method, I've used it in the past and yes it is terrible but was effective back in the day when we didn't know any better.
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809584
Yeah well pre a-applied is okay.
But i would allways recommend to just put some new paste on it.
Like i said something like Noctua NT-H1. or artic silver MX4/5 if you like to pay for that... will be fine offcourse.
But in the main, there is not much of a diffrence in thermal compounds for that matter.
Its more how you apply it.
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809624
It's fine but there are differences, they use different materials and you should consider ageing the Arctic silver has amazing ageing.
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809654
These days there are very little differences with the exception of aging.  I mean you might get a 1 degree difference between the compounds which isn't the biggest deal, but the cooler the better.  Don't worry about paying a premium for thermal paste though and get the $5 mx-5 instead of the $12 ic diamond (just an example).
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3809723
I've got Arctic Silver 4
        »»» Frankz' X99 System «««
CPU: 5820k 4.6Ghz 1.31v, Motherboard: Asus Rampage V Extreme, RAM: G.Skill Ripjaws4 16GB DDR4@3000Mhz, GPU: ASUS GTX780 DirectCUII
         SSD: Samsung 850 EVO 250GB, HDD: WD Blue 1TB, PSU: EVGA SuperNova 850 G2, Cooler: Corsair H105, Case: Corsair Obsidian 750D
https://linustechtips.com/topic/280569-cpu-thermal-compound/#findComment-3810235
