first pc buil
Solved by c0d0ps,
Ok.
I will get the R9 280 and I guess I will pick the AMD because, if I´m not happy I can still change it later
also, can you change the power supply to corsair.
Yeah, you can always change.
And look at some benchmarks before you order to see that it is stronger.
I have already changed to 550w gold certified psu from corsair.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
