Hi guys, I need your help. I recently changed my graphic card from GT 9600 to R7 260X. I see the performance difference in my system but not that much. So I have the doubt that, Is my system facing bottleneck prob?
My System config,
Core2 Duo E7400 @ 2.80GHz.
4GB ddr2 ram
500gb HDD
2GB R7 260X graphic card.
Help me guys. Thanks in advance.
https://linustechtips.com/topic/280380-is-my-system-bottlenecking/
Yes that CPU is bottlenecking your graphics card by quite a bit.
Also the DDR 2 RAM is slowing you down in heavy tasks. That RAM is almost as slow as your grandma.
(BTW welcome to the forums ;))
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
yes your CPU and RAM are the culprits
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Thanks for support. Pls suggest me in this. Shall I upgrade my processor by now or shall I wait for release of skylake architecture based processor in 2nd half of 2015. Why Im asking this because the processor im using is old one, I think pentium series. If I upgrade now, then in few months this will get old, because completely new architecture based processor will be out at the time. So whats your suggestion. Thanks in advance
what is your budget of the new CPU,Mobo and RAM?
if you can afford now
just wait a while longer for Skylake
you know, that if you are on a tight budget you can do this:
buy a 775 core 2 quad (so you dont have to change your mobo)
and buy another 4gb of ddr2 so you have 8GB memory
that will keep you up and running for a little while if you dont have so much money
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
Desktop Skylake is coming in Q1 2016! Next year is Broadwell, and mobile Skylake in Q3 of 2015. Also Skylake focuses primarily on power efficiency and better on-board graphics more than anything else. The IPC will increase with around 5-10% at best. If you want to upgrade now, just do it, there is always something around the corner, especially on the mainstream Intel platform with its yearly upgrade cycles.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
CPU: http://www.idealo.de/preisvergleich/OffersOfProduct/4429667_-pentium-g3258-box-sockel-1150-22nm-bx80646g3258-intel.html
Mainboard: http://www.idealo.de/preisvergleich/OffersOfProduct/4052814_-h81m-e-asus.html
RAM: http://www.idealo.de/preisvergleich/OffersOfProduct/3248412_-entertainment-8gb-ddr3-pc3-10600-cl9-ae38g1339u2-amd.html
Those components cost about 150$
You can buy a better mainboard, if you want to overclock the shit out of it
Thanks for reply. So you saying both broadwell and skylake will perform same with some power efficiency and slightly better performance. So then shall I go with broadwell?
What I am saying is that there is no point of waiting an entire year for the unlocked desktop Skylake processors if you are in need of an upgrade now, which you obviously are. An i5 4690K will be plenty fast an will not bottleneck even two of those cards.
