So i just built my new computer and i have decided its time to get into water cooling and overclocking, the problem is that I didn't know i did when i bought it. So i chose the asus direct CU 2 graphics card (680 2gb 1084 mhz) and now i cant find a block for it.
Basically all i want to ask is if anyone knows a mid priced water block for the asus DCU2 680
Intel i7-3770k @ 4.5 GHz                               DCUII GTX 680                            16GB Corsair Vengeance RAM
Sabertooth Z77 ATX                                      WD Caviar Blue 500GB+ 1TB      Corsair Obsidian 750D
Corsair TX850M Watt PSU                            Bad Custom Water Cooling          Samsung 840 Pro SSD
https://linustechtips.com/topic/2802-direct-cu-2-liquid-cooling/
thanks man
https://linustechtips.com/topic/2802-direct-cu-2-liquid-cooling/#findComment-36878
