I have just built a pc with a maximus vi hero, I had got through the bios, and began installing windows when my system suddenly shut off. i rebooted fine, all the fans booted and the debug led shows AE, however, nothing is coming through the hdmi cable onto my monitor, it acts as if the computer is off. If it helps, the shutdown occured mid instillation when i nudged a psu cable by accident :/
https://linustechtips.com/topic/28005-bios-wont-appear-please-help/
uhmm
check the psu cables to the gpu?
like put some force on the gpu also you might not have it seated right
and if none of that works
hook a video cable to your integrated graphics on your cpu and boot it then after you remove your gpu
If I had one wish, I would ask for a big enough ass for the whole world to kiss
this happend to me try resting the the cmos
I just got a repair guy in and we tried everything. Turns out that he thinks that the motherboard had issues when it arrived and its just got worse. So i'm sending it back as DOA. Not great for a first PC build :/
Hopefully it all turns out ok.
Keep us posted.
These things happen unfortunately, though quite rare but still they happen, don't let it put you off :)
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
