i am looking for a small fan controller to run two fans. I need it to be small as possible. i only have 2 fans that it needs to run and i would perfer it automatically adjust the speed. thanks! :)
If your motherboard is capable you can control it via it's software with it's fan headers, if not or you want something with more control the NZXT grid+ allows for custom fan curves and controls through software.
http://www.nzxt.com/product/detail/148-GRID-digital-fan-controller.html
https://linustechtips.com/topic/279974-small-fan-controller/#findComment-3801259
Just use a fan splitter on your PWM mobo header.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/279974-small-fan-controller/#findComment-3802571
