Need help for choosing a gaming monitor
Supergun1
Go to solution Solved by andre82693,
Asus VG248QE
Okey so I'm looking for a great gaming monitor that will have a great contrast ratio and that the games will look beautiful on it. My budget is MAX 300€. And I'm looking also help should I buy 144Hz or 120,60Hz. I will also need 1080p or more if you guys think my pc can handle it.
My PC Specs:
GPU: Amd Radeon 7950
CPU: Intel Core I5 3570K 3.40GHz
OS: Windows 8.1 64-bit
8GB Ram
And also, just so you don't start to question what is my current one, here is the link, BUT I WARN YOU, it's gonna destroy your eyes
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/907/c00603943.jpg
I play games like Arma 3, Battlefield, csgo, War Thunder,Payday, Total War, Civilization,Rust. As you can see, it's kinda mix of fast-paced games and more graphic oriented games.
I'm not sure if that GPU can handle the 144Hz, but I would get the BenQ XL2420T ;)
"an obvious supporter of privacy"
I saw it, and argh my eyes. Would recommend the VG248QE, first seller in amazon for a reason.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
What do you mean that my GPU can't handle 144Hz? Does the 144Hz need more power from the GPU or you mean that my GPU can't get the 144fps to enjoy it's full aspect?
In order to enjoy 144Hz properly, your GPU must output 144FPS or more. That's why ;)
Asus VG248QE
I'm debating on whether getting the VG248QE or the  BenQ XL2411Z, they both look pretty good and I have heard a lot of good reviews about each. Do you have the VG248QE? If so how good is the picture quality? Obviously its a TN panel, so it wont won't  be anywhere near as good as a Ips monitor but I really want the 144hz refresh rate which I can't get on a Ips. Also how good are the speakers? Good enough or will i need to purchase some others to go with it?
Thanks.
Edit - link didn't work    http://uk.pcpartpicker.com/part/benq-monitor-xl2411z
 Do you have the VG248QE   --- NO plan on buying it . JayzTwoCents review got me
 For the speakers No buy speakers
 If you can push out 144hz  get  VG248QE
I agree with getting the asus vg248qe http://pcpartpicker.com/part/asus-monitor-vg248qe
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
I'm now just wondering, my GPU can't get over 60fps on most of the games I play, except War Thunder,Payday,CsGo,Rust, so would it actually be worth it to buy the VG248QE? Also, I'm kinda saving money for the AMD R9 290X Lightning, and after that, for new motherboard and Intel I7-4970k processor. So I wouldn't really wanna spend all the money to a high end screen that's aspects i can't fully enjoy. But on the other side, I would now want to buy a good monitor so when i get to upgrade my pc, I can enjoy it then. So what do you guys think?
I would say yes incase you ever sell your gpu and buy a new one.
Okey thank you all for getting me decide what monitor to choose. I appreciate it. Might seem like a ordinary thing, but every single thing what we make for other to make him happy... Should be appreciated
