clean my hard drive
Go to solution Solved by Godlygamer23,
Format it. Right click on it in Windows Explorer and click Format. Make sure it's NTFS and make it a quick format. Click OK.
i just got an SSD and installed windows on it
I've hooked my old HD to my pc but it has the old OS on it and useless junk
is there a way to erase everything on the hard drive that way I've got a blank mass storage device
the hard drive ways part of a pre-built computer before i moved it to my custom built one.
https://linustechtips.com/topic/279372-clean-my-hard-drive/
https://linustechtips.com/topic/279372-clean-my-hard-drive/#findComment-3792049
Format the hdd.
The Guides and Tutorials section is for posting guides/tips and not asking for assistance. I'm moving the thread.
https://linustechtips.com/topic/279372-clean-my-hard-drive/#findComment-3792053
