USB BIOS FLASHBACK PROBLEM
Go to solution Solved by Godlygamer23,
I know this however my revision is 1405 people are saying I need to update for it to be compatible with the i5 4th gen. I'm just struggling to understand how the flashback thing works
There are different ways it can be done. Personally, I prefer to do it directly through the motherboard. Grab the BIOS revision from ASUS website(I would grab the latest one. It contains everything from the previous revisions). Put it on a flash drive in the root file system. After doing that, shut down the system and hold down the Flashback button. It should start flashing - it'll continue flashing until it's finished(if I remember correctly. Reference your manual in case I'm wrong).
My motherboard Sabertooth z87 bios don't support the 4th gen processors.. I can't get past post with my new computer so I have to use the utility usb bios flashback there is a file on the ASUS website for the new bios however I'm not too sure how to format it correctly onto the USB ready to be used. The ASUS website dosnt make IT clear
Please help
The file is: BIOS updates for New 4th gen Intel core processors (version: 2.00.02)
https://linustechtips.com/topic/279221-usb-bios-flashback-problem/
Z87 supports Haswell. It uses socket 1150 and that's what Haswell uses. It wouldn't make sense if it didn't support Haswell out of the box. In fact, the motherboard would be put in an unusable state.
If this was the situation why would ASUS supply a bios updated for this problem?
And to be honest it is unusable
If you look at the BIOS revisions, you can see they've made MANY revisions. They're simply improving support for the Haswell CPUs. Haswell is the ONLY supported CPU architecture on the board because it uses LGA1150. Version 1707 is where they start their Haswell CPU BIOS revisions. I'm not saying you shouldn't update your BIOS to the latest version. I'm just saying Haswell MUST be supported out of the box(unless it's an early sample) because no other CPU architecture works on it.
Here's their list of BIOS revisions. http://www.asus.com/us/Motherboards/SABERTOOTH_Z87/HelpDesk_Download/
You have to get another CPU (like the i5 4440), install that, update the BIOS, and then you can use the 4th gen intel CPU like normal.
Gigabyte boards have this issue too, and i don't understand why this isnt fixed out of the box by now.
Go to a tech shop and see if you can use the bench for an hour so you can fix this.
EDIT: Your motherboard has a BIOS flashback button on it,.
Get the latest BIOS from the website, put it in the root of an empty flash drive, plug that into the machine and press the BIOS flashback button on the motherboard.
The BIOS flashback button is the two arrows that look like a refresh key on the rear I/O.
EDIT TWO: Also make sure you plug it in to a USB 2.0 port (one of the black ones, on the top end of your I/O. There are 4 of them.).
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
This sounds like a you problem. Sorry :(
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
Refresh aren't supported without a BIOS update...
OP, I think you just plop the file on a fat32 drive.
