Hey guys, i'm not really sure where this thread should go but here it is. What are some of the best surge protector/power strips on the market in terms of price, reliability, # of plugs, and features? And which ones do you guys personally use?
Thanks! :)
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/278588-power-stripsurge-protector/
Thanks! :)
Most will do that job just look for one with high joules rating, it's a basic way of looking at it but generally a good rule of thumb, as for brands, APC, Belkin, Tripplite are all good.
Thanks! :)
Unfortunately it's hard to tell the difference between good ones and bad ones, without reading detailed reviews on.
However, as long as you don't buy it at the Dollar Store, then it's probably good.
Make sure to get a high protection rating for a PC (I usually go anywhere from 2500 to 3500 Joules of protection). And then for the rest, just get the features you want. Obviously any real surge protector will have a reset switch. Otherwise get the number of Outlets you need/want, and whatever additional features you may want (RJ11 phone passthru, Coaxial Cable passthru, etc).
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
I've also got some Phillips ones that are pretty good.
APC is great for anything power related. Their UPS's are excellent.
Yeah can't really go wrong with surge protectors and for APC their UPS work great even though i have one is way past it's recommended 3-4 year replacement for a battery.  :D
@Tie Lightning
If you happen to have a Costco or big box store this one I fairly like personally it's layout is nice and has basically everything for you'd ever want to surge protect.
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=P11VNT3
@Tie Lightning
Thanks guys! i need to buy 2 of them and i think ill pick up the ones that @W-L linked in his post. Thank you :)
I use that one as well. APC is one of the best brands out there. Tripp Lite is good too. You can pick that one up at Sam's Club for pretty cheap too.
Get APC. :P
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
