Pumps should be under the res and where are the return line from rad to res?
I am the one who goes bump in the night... usually making a sandwich.
Case: Phanteks Enthoo Primo White - Motherboard: ASUS X99 Deluxe - CPU: Intel i7 5820k - RAM: 4x4GB Corsair Vengeance 2666mhz ddr4 - GPU: Dual EVGA gtx 980 SSC - PSU: EVGA G2 Supernova 750w - Cooler: Custom PETG Loop on cpu and gpus - Storage: 500gb Samsung 850 evo ssd, 2x Seagate Barracuda 7200rpm 3tb hdd
https://linustechtips.com/topic/278368-pc-watercooling-plan/#findComment-3774790
Don't worry about having hot water from the GPU run to the CPU or otherwise around. That's a common misconception, the water actually only changes by a few degrees after going through waterblocks.
Also, your watercooling setup should be a loop, as Bosco said. One Reservoir+Pump should be fine and the bottom rad is too big and might be obstructed if you don't have good case feet.
I recommend Dazmode on youtube, they do a lot Watercooling help
Do you even custom Bios, bro?
https://linustechtips.com/topic/278368-pc-watercooling-plan/#findComment-3776103
