More CSS help
Go to solution Solved by Jeroen1322,
In the console it should say what line number it is so look that line number up and change it there. Maybe the color is for that text is defined twice.
 So right now im making a dark theme for a website and somehow it wont let me change color of some text. Weirdly enough the code is not written with !important  so shouldn't i be able to change it? Also when i go in (name of the text) element.style is empty. I can change it in the f12 console but when i write the name and color change in my stylish code nothing happens.
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
https://linustechtips.com/topic/278285-more-css-help/
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/278285-more-css-help/#findComment-3772950
hmmm i can't seem to find it. I just have the feeling that im doing something wrong -_-
https://linustechtips.com/topic/278285-more-css-help/#findComment-3773005
This is the actually html code line for one of the text i wanna change (i have highlighted the part) <div style="display:inline-block;opacity:.1;color:#cbcbcb;">2646</div>
https://linustechtips.com/topic/278285-more-css-help/#findComment-3773161
