Note: if this is in the wrong section please let me know.
so in my Corsair Spec 01 there are two places (top and front) to mount a 240mm radiator. Unfortunately, i cant use the top mount due to ram clearance. so that leaves the front. But wait! in order to put one in the front I must remove the HDD cage. Its not hard, just four screws. But then if i dont have a cage then mounting hdds is kinda tricky...
so can i just leave it sitting in the bottom of my case? I could easily cut up some soft foam and tape it on to that. or could i put it in the back with the cables?
thanks for the help,
-Milo
https://linustechtips.com/topic/278266-wherehow-to-mount-hdds/
What kind of foam do you have and what drives are you mounting/'putting'?
https://linustechtips.com/topic/278266-wherehow-to-mount-hdds/#findComment-3772818
im not 100% sure as its my dads, he uses it for his model trains. its about 5mm thick, nice and squidgy... uhh.. thats what i know...
Can you post some pics of the RAM issue?
i dont actually have the rad yet but i saw an OC3D review that showed that only low profile RAM works with the rad and fans installed
https://linustechtips.com/topic/278266-wherehow-to-mount-hdds/#findComment-3772851
Can you post some pictures of the foam? Also, what hdd's do you have?
Yeah, it wouldn't fit. Ripjaws are 40mm tall.
https://linustechtips.com/topic/278266-wherehow-to-mount-hdds/#findComment-3772869
i'm so sorry, but im newish here :/ how do you post a picture in a reply? and my HDD is a "1TB Seagate Barracuda ST1000DM003 3.5" SATA III Hard Drive"
You can upload a picture to imgur, gyazo, etc. and link them like this:
or you can use the Full Editor to upload images.
I suggest sticking to the first method to put less of a load on the forum.
https://linustechtips.com/topic/278266-wherehow-to-mount-hdds/#findComment-3772917
sorry for the wait,slow wifi cuz the whole family is home over xmas.
http://imgur.com/cYGIBhK
but here it is being squished by a pencil
https://linustechtips.com/topic/278266-wherehow-to-mount-hdds/#findComment-3772980
