Quick question about sound cards
Go to solution Solved by ImBleu,
Sound cards could be compared to GPUs. If you plug in a GPU you generally disable the Integrated iGPU on the CPU (assuming it has a iGPU). Likewise goes with soundcards and the onboard audio. The onboard audio is just an Integrated low-level sound card. If the Soundcard has the needed outputs, it'd work.
Trying to get a surround speaker setup to work, motherboard doesn't have the necessary outputs. First off, would a cheapo soundcard be the best option? Also, does installing a sound card disable the onboard audio completely? Like, I couldn't just plug headphones in to my motherboard when I wanted to use them.
Thanks.
https://linustechtips.com/topic/277718-quick-question-about-sound-cards/
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
