Hi! My temperatures on my FX-6300 are really weird, they´re kinda low, like really low. I dont know if it´s a problem with the sensors or if it should be like that. The cooling is done by a CM EVO212 with a Noctua NF-P12. Should it be like this? Is something wrong? (BTW running Prime 95, that´s why the load is at 100%) post-57327-0-90803500-1419602163.pngpost-57327-0-07527300-1419602183.png
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
https://linustechtips.com/topic/277472-fx-6300-temps/
Hi! My temperatures on my FX-6300 are really weird, they´re kinda low, like really low. I dont know if it´s a problem with the sensors or if it should be like that. The cooling is done by a CM EVO212 with a Noctua NF-P12. Should it be like this? Is something wrong? (BTW running Prime 95, that´s why the load is at 100%) attachicon.gifCore Temp bild.pngattachicon.gifSkärmbild (12).png
There are a lot of problems with AMD temperature sensors this can't be normal even on idle
https://linustechtips.com/topic/277472-fx-6300-temps/#findComment-3764913
Yeah that´s what i thought and even with the stock cooler it was down at 19 degrees.
https://linustechtips.com/topic/277472-fx-6300-temps/#findComment-3764927
if the sensor is faulty, and i'm not saying go to your hardware store and purchase one of these, but if you can borrow from a friend/family its an external way to check temparture.
or just shove a rectal thermometer into the fins of your cooler, that will buff out. DONT DO THIS. PLEASE. I MEAN IT. DONT.
may your framerates be high and your temperatures be low. #pcmr
https://linustechtips.com/topic/277472-fx-6300-temps/#findComment-3764980
Why have your tried it ?
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/277472-fx-6300-temps/#findComment-3765112
lol no i didnt, but im pretty sure it would damage the cooler.
Perhaps.
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/277472-fx-6300-temps/#findComment-3765163
lets try it! you know, for science and stuff.
Yeah sure I don't have a PC so who will be the donor ?
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/277472-fx-6300-temps/#findComment-3765305
and I don't have an after market cooler. neither do I have a rectal thermometer. this meeting is adjourned.
Yep this is proven to be useless so meeting dismissed.
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/277472-fx-6300-temps/#findComment-3765376
