1440p Gaming Monitor Help
PigGong
Hi guys! I'm soon going to build a new gaming PC and I need your help deciding on the monitor. I'm getting a GTX 970 Gaming G1 form Gigabyte. I want a good 1440p monitor and my budget is about 550-600$. I'm really not familiar with monitors so I'd really appreciate if you could explain your reasoning for choosing a specific monitor. Also I'm 90% sure about going for the 1440p one but you tell me if it's worth it :D Again I will be using it for heavy gaming and (don't kill me) watching anime. Thank you for helping!
Also tell me if you need some more information!
Asus PB278Q
Adding additional $165 can get you best gaming monitor, the ROG Swift!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
Asus PB278Q
He should get the updated PB278QR instead.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
Asus PB278Q.This is a WQHD so definitely recommended for watching shows and gaming,also it features a pivot tilt so you have more customisation capability
Link to my knowledge google.com .My most beloved store newegg.com
My tech:PS3,
i5 4690k,Msi R9 390,1600 mhz DDR3 8GB Avexir,Gigabyte Z97 Gaming 3,Corsair Carbide Spec 03,Cooler Master VS650,Philips E Line 22 inch monitor,A4Tech illuminated kb crap and Gigabyte Force M7
i5 4200u,GT 740M and 4GB RAM
Yeah!
Almost forgot that it has newer version!
Asus PB278Q
The ROG Swift is too expensive in my country (Serbia). Something like 1000$. So that's off. And you can't find that ASUS one in here either. I've been thinking about the Dell U2713HM but I've also heard some bad things about it's gaming capabilities and overall performance.
Yeah, pretty much what @kameshss mentioned before, the Asus PB278q is the best monitor in your price range but it you want a "gaming" monitor go with the ROG swift, its 1440p, 144hz etc but it depends on how much you can go over your target budget.
 CPU Intel Core i7-4790K  | Motherboard Asus Sabertooth z97 Mark 1 | RAM Corsair Dominator Platinum 16gb 1866mhz | GPU EVGA GeForce GTX 980 w/ ACX 2.0 | Case Fractal Design Define R4 w/Window | Storage Western Digital BLACK SERIES 3TB 3.5" 7200RPM + Samsung 840 EVO 250GB |  PSU Corsiar RM750 | Display(s) Some Acer Things | Cooling Corsair H100i + 5x Noctua NF-F12 industrial 120mm fans(they are freaking load) | Keyboard Corsair Vengeance K95 |  Mouse Logitech G502 | Sound Audio-Technica AD900x + 02+ODAC +AT2020 | OS Microsoft Windows 8.1 Pro
You can't find Asus PB278Q too?
Nope. Although I can squeeze in the ROG if I get just a little bit cheaper MOBO and a cheaper SSD. Right now in my plan there is a ASUS Z97 Sabertooth Mk2 and a Samsung 840 EVO 250GB. Right now I'm 200$ away from the Swift.
Can you link the store site?
I can look into that for cheaper mobo and SSD
www.emmi.rs        Don't have ROG.
www.monitor.rs     Have ROG.
Those are the ones that I mainly use!
