So ive just bought and installed my AMD Fx 8320 and got a nice stable OC at 4.5 ghz, and I'm a very happy man.
But i still have my old GTX 560 from years and years ago! and its really stopping my gaming performance, especially since i just got into battlefield 4!
Ive got around £240 to spend on a new GPU, so i could have a pretty nice system overall, but my problem lies in my monitor and which GPU i pick!
I was orginally going to buy an AMD r9 290, as its a great performing card, and just in my perfect price range.
But it only has DVi-D outputs on it!
And my current monitor only supports that crappy blue wire that we like to call VGA
Now Digital and analogue dont mix, so that throws out my R9 290 quite quickly!
So what i need some help with is this
What graphics card can i buy for £240~~~~$340 that will support my VGA monitor through DVi-I or DVI - A as i know you can get adapters for them!
Many Thanks Guys
Sam.
https://linustechtips.com/topic/276752-gpu-help/
The R9 290 comes with a DVI to VGA adapter...lol... I think EVERY card does =).
Edit:  I guess I am wrong.  It doesn't.  I have 4-5 of those adapters lying around...somewhere.
I have a 4-5 year old LG as a second monitor... 22'', 1680x1050.  I have it connected VGA to my R9 280's HDMI.  It works fine.  The cable cost me $10.
Edit..again:  I just looked.  I connected the monitor to it's DVI, not the VGA.  The adapters will work still.
https://linustechtips.com/topic/276752-gpu-help/#findComment-3756773
The R9 290, You just need a adapter.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/276752-gpu-help/#findComment-3756780
old cards does not have them, because most of them already has VGA
GIGABYTE GV-R929XOC-4GD Radeon R9 290X 4GB 512-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card
I think its time to upgrade to HDMI age buddy, i wont complain yes i do have VGA monitor but will soon upgrade for ease of upgrade. And yes Most modern cards have DVI to VGA adapter
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/276752-gpu-help/#findComment-3756784
I think its time to upgrade to HDMI age buddy, i wont complain yes i do have VGA monitor but will soon upgrade for ease of upgrade. And yes Most modern cards have DVI to VGA adapIt just eats a massive chunk into my
This would eat a massive chunk into my upgrade cash, ive saved up the 240 just for this upgrade and it would take me considerably longer to get a new monitor. so this isnt a possibility!
Also everyone saying DVI to VGA adapters
The R9 290 only has DIGITAL outputs
DVI - D
Displayport
HDMI
Non of these will allow me to use a VGA adapter as they are all DIGITAL.
I would Need an Expensive Active Adapter which are £40 ~~~ $63 here, and thats just way to much to add onto the cost.
All i want to buy is a Graphics card similar to the R9 290 perfourmance, with VGA Support through adapter, and at my £240 which really cannot budge!
https://linustechtips.com/topic/276752-gpu-help/#findComment-3756903
DVI - D
Displayport
HDMI
m8 its 330$ its like 220£. Adapters comes with the GPU inside, DVI to VGA adapters comes with most of the cards now m8
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/276752-gpu-help/#findComment-3756984
I dont think your understanding the problem...
Their is no such thing as a DVi- D to VGA Adapter
Their is such a thing as a DVI- I to VGA as these are still analogue signals 0 this is what im using at the momment and looks like this.  --- http://www.ventincre.com/Product%20Images/DVI%20DVI-I%20(M)%20to%20VGA%20(F)%20Video%20Converter%20Adapter/DVI%20DVI-I%20(M)%20to%20VGA%20(F)%20Video%20Converter%20Adapter.jpg
You cannot use an adapter like this for DVI - D to VGA.
The R9 290 has 2 DVI- D ports 1 Display Port and 1 HDMI Port
https://linustechtips.com/topic/276752-gpu-help/#findComment-3757051
dual link dvi, i understand... misread it soz. #0yourfucked
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/276752-gpu-help/#findComment-3757276
