Need Help with graphics Card
Solved by ImBleu,
Ok! also to quote the 8 pin one says "CPU" ... does that matter?
This is how you should plug it in:
20+4 pin into the ATX power
8 (4+4) pin CPU into the CPU power (top left of most boards)
4+4 pin & 6+2 (or 2x 6+2) (whichever) into the GPU.
They don't matter at all, if it fits it works, just they generally make the CPU one long enough to get to the motherboard power, while making the other ones shorter to reach the GPUs instead. As long as they all fit it's alright.
