Hard drive not working ?
Go to solution Solved by belgiumkiddo,
It worked i installed and formatted my new hard drive succsesfully thank you for all the help :)
> inb4 @Captain_WD @Mighty_Miro_WD
Are you sure both SATA power and data are connected, and that the sata data is plugged into the appropriate Sata port on the motherboard (if you have a M.2 SSD it generally removes Sata port 6).
Is this the only HDD in your system? Is it perhaps that you haven't selected it as the boot device in your Bios?
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/276728-hard-drive-not-working/#findComment-3756466
Check under Disk drives in Device manager. If detected, Right click computer --> Manage --> Disk Management --> If your drive says it's offline, right click and select online then format it!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/276728-hard-drive-not-working/#findComment-3756467
It needs to be formatted in Disk Management.
https://linustechtips.com/topic/276728-hard-drive-not-working/#findComment-3756472
I connected the power cable and the Sata cable. It's my second HDD in my system and i am not planning on using it as a primary drive.
https://linustechtips.com/topic/276728-hard-drive-not-working/#findComment-3756479
What is formatting and what does it do ?
HDDs (and SSDs) can be formatted differently, this is typical between some OSes using different formats and having read-only style formats.
Or as Wikipedia would say:
Disk formatting is the process of preparing a data storage device such as a hard disk drivesolid-state drivefloppy disk or USB flash drive for initial use. In some cases, the formatting operation may also create one or more new file systems. The first part of the formatting process that performs basic medium preparation is often referred to as "low-level formatting".[1] Partitioning is the common term for the second part of the process, making the data storage device visible to an operating system.[1] The third part of the process, usually termed "high-level formatting" most often refers to the process of generating a new file system.[1] In some operating systems all or parts of these three processes can be combined or repeated at different levels[NB 1] and the term "format" is understood to mean an operation in which a new disk medium is fully prepared to store files.
https://linustechtips.com/topic/276728-hard-drive-not-working/#findComment-3756488
I switched Sata cabels  between my 2 HDD's and changed the boot order in my BIOS. Now my PC detecs both HDD's. I have the option to convert my new hard drive to a GTP dirve or to a dynamic drive which one should I choose and is it nessescary to do this ?
https://linustechtips.com/topic/276728-hard-drive-not-working/#findComment-3756584
Hi there @belgiumkiddo!
You need to initialize your hard drive first. Here's an article from our knowledge base with steps how to do so:
http://products.wdc.com/support/kb.ashx?id=ncTOkY
Hope this helps and happy holidays!
@ThatCoolBlueKidd, thanks for mentioning me here - I really appreciate it! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
https://linustechtips.com/topic/276728-hard-drive-not-working/#findComment-3756636
