Help with SSD
Go to solution Solved by cesrai,
Here you go m8 watch this video
@Tickinginsanity
Well...You are no help *no offensive* Thanks anyways.
Its no offense not no offensive...
That is supposed to be it, its impossible to install windows without a disk or a usb (Unless you have a external HDD). But I said in my knowledge, because someone MIGHT come up with a way that is totally mind blowing, like baking a gpu -_-
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/276503-help-with-ssd/#findComment-3753839
Okay..I know how to do that..But will it give me a option to download it to a different drive?
OK, so do oyu have your computer up and running or is it a new build... Because if you can access windows, download daemon tools, mount the iso. Run the setup through autorun. Go through the process, select your ssd as your installation and be happy!
https://linustechtips.com/topic/276503-help-with-ssd/#findComment-3753863
@Tickinginsanity
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/276503-help-with-ssd/#findComment-3753873
Its my main build..i've never done this before..Sorry for being so stupid..My depot is GPU's..Okay yeah because i used Microsofts installation Media thing. and i made a ISO and i got it mounted...So i guess im gonna re-install i will be back to see if it worked.
https://linustechtips.com/topic/276503-help-with-ssd/#findComment-3753883
