My build won't work and I can't figure out why
Solved by Elven,
Heya,
Take out the gfx card and try plugging the monitor cable into the motherboard. See if it works that way.
The motherboard doesn't have integrated video outputs.
Does the motherboard make any beeping sounds when you try turning it on? If the 560 defo works and it still doesn't boot up, it could possibly be the memory. Have you tried posting with one of the memory modules?
Elven
Featured Topics
QMalcolm ·
Posted in General Discussion1 -
FrozenHydrangea ·
Posted in Troubleshooting0 -
LingoInv ·
Posted in Graphics Cards1 -
1
EzioWar ·
Posted in CPUs, Motherboards, and Memory1 -
Zham ·
Posted in Troubleshooting19
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
