as long as the one with a higher wattage capacity and output is plugged directly into the wall, theoretical there shouldn't be much issue. I personally wouldn't do it.
Still though,, its probably a bad idea in general
CPU: AMD FX8350 @4.4GHz | MOBO: ASUS Sabertooth 990FX R2.0, 990FX chipset | RAM: 16GB (4x4) dual channel Patriot Xtreme series DDR3 @1866MHz @1.65V | GPU: Asus Radeon R9 Fury Strix| PSU: Corsair AX860i 860 watt | CPU cooling: Noctua NH-D15S + additional Noctua NF-F12 | Case:Corsair C70 Black | Storage: 3x 128GB Samsung 840 pro SSDs; 1 for the OS, 2 in RAID 0 for games. 3x WD Red 3TB HDDs in raid 5 for bulk storage | Displays: 1x Dell 3007WFP 30 inch 2560x1600 IPS LCD. 1x I-Inc IH253DPB 25 inch 1920x1080 TN LCD | Keyboard: Corsair K70 with Cherry MX brown switches + Blue LED backlight | Headphones: Sennheiser HD 280 Pro | Mouse: Logitech G600 @1100 DPI | OS: Win 10 Pro 64 bit |
Mfg/model number: Clevo/W355SSQ | CPU: Intel i7 4710MQ @3.5GHz  | MOBO: W35xSS_370SS, HM87 Chipset | RAM: 16GB (2x8) dual channel Crucial Ballistix DDR3 @1866MHz | GPU: GTX860m 2GB Gddr5 | Battery: 76,960mW/h 8 Cell battery, 3 Hrs full on a full charge | Storage: 1x 128GB Samsung 840 pro SSD for the OS. 1x WD Red 1TB HDD For storage and games | Displays: 1x 15.6" 1080p LCD | Keyboard: Full 103 key back-lit keyboard | Mouse: Logitech M510 | OS: Win 10 Pro 64 bit |
https://linustechtips.com/topic/276404-ups/#findComment-3752529
I don't know.... I can't think of a reason why it wouldn't be, but I can't give you a defiant answer.
Is it bad that my dream setup only costs a few thousand not counting the obutto?
CPU: FX-8320
Motherboard: asrock 970Pro3 r2.0
Memory: Team Zeus Blue 8GB DDR3-1600 Memory
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card
Case: Deepcool TESSERACT BF ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Certified ATX Power Supply
SSD: MX100 128GB
HDD: WD 2TB black edition
https://linustechtips.com/topic/276404-ups/#findComment-3752533
Why not just buy a high quality UPS that is reliable, also you should check your UPS and do maintenance to them from while to another, I would suggest your reading the manual when for example that your UPS battery is getting low and others...
Back to your question I can't see a reason it wont.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/276404-ups/#findComment-3752538
my dads a technician, and people sometimes are giving him "broken" ups, which he finds are perfectly fine. so we have like 5 good ones from apc and i don't know what to use em for so i was thinking of dasiychaing them xD
https://linustechtips.com/topic/276404-ups/#findComment-3752552
I can't see a reason you would do that a UPS isn't to run a PC on for a while, you use your UPS to save your work for example when the power go out, I really can't find a reason to do that maybe use the UPS for other valuable machines like a TV.
You said your father is a technician why not ask him ?
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/276404-ups/#findComment-3752573
There will not be a increased safety, As i see it there would only be adding more points of failure.
It wont becomes safer, Just more messy And if one of them breaks it would still interrupt the entire chain.
A part of my work as a electrician are pretty much checking for stuff that has with UPS systems and such.
But modding one to have a higher charge may work.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/276404-ups/#findComment-3752580
hes not home atm xD. Iknow, meant it for wifi, just chain that one, and i did. ;)
https://linustechtips.com/topic/276404-ups/#findComment-3752608
yea, not talking about safer, if its isnt safe, just for the wifi, i was thinking 2, to keep it running for a while.
https://linustechtips.com/topic/276404-ups/#findComment-3752613
See the post that the other m8 gave it may be interesting.
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/276404-ups/#findComment-3752616
How many Amp Hours do they have? Id say just one would be enough for a couple of hours if it only is a router/wifi that needs power.
My Gaming PC
https://linustechtips.com/topic/276404-ups/#findComment-3752647
