 CPU: Intel i5 4690 3.5Ghz Quad Core
CPU Cooling: Zalman x5 Performance Heatsink & Fan
Memory: 16GB DDR3 1866Mhz Vengeance (8GBx2)
Motherboard: Gigabyte B85 with USB 3.0 Support
SSD Hard Disk: Optional Extra
Hard Disk 1: 1 Terabyte UDMA600
Hard Disk 2: Optional Extra
Optical Drive: LiteOn 22X DVD Rewriter
Video Card: NVIDIA GeForce GTX 970 4GB
Sound Card: Realtek ALC887 8-Channel HD with BluRay Support
Wireless: Optional Extra
Power Supply: FSP 500 Watt 80+ SBronze Certified PSU
Operating System: Windows 8.1 Standard 64 Bit
https://linustechtips.com/topic/275580-need-help-new-pc/#findComment-3742025
Without another cable it's gonna be hard. Only things you could try would be another port on the TV.
I can be a bad cable, bad port on the PC, bad port on the TV, settings to change in the BIOS...
EDIT : I guess that's plugged in the 970 ? If so, is the card sitted correctly and powered with the 2x6pins power ? The fans are spinning ?
https://linustechtips.com/topic/275580-need-help-new-pc/#findComment-3742053
You're fucked xD
You'll need a adapter for which seems to be mini display port to HDMI.
Yup. If you want to use onboard graphics you'll need either a VGA or DVI cable. But if you have a DVI cable, the port on the far left on the external card will work. I've never seen a 970 with 3 mini display ports.
https://linustechtips.com/topic/275580-need-help-new-pc/#findComment-3742196
Theoretically that HDMI out on your motherboard should be working. But it won't be using your 970. I don't know if it's because the card is plugged in that it's turn off or you need to set something in the BIOS to use it...
Maybe somebody else could help you get this computer working using the onboard graphics for now. But you'll definetly want to plug your monitor directly in the card. Be it with a displayport cable or an adapter to HDMI.
https://linustechtips.com/topic/275580-need-help-new-pc/#findComment-3742199
You will need a DVI to HDMI cable, display port to HDMI cable, or a Micro HDMI to HDMI cable to use the Video card in that thing. Not sure that the Micro HDMI port will work out of the box on your card with out some tweaking though. I would try and get a DVI to HDMI cable or a display to HDMI cable.
In an attempt to get the onboard graphics card working with what you have, take the graphics card out. See if the HDMI on the Motherboard will work automatically.
Alternatively you can use the DVI port on the card to plug into a monitor that has DVI for the mean time, if that is an option you have available.
https://linustechtips.com/topic/275580-need-help-new-pc/#findComment-3742231
by default when you plugged in your dGPU the onboard will be de activated
if you need to get the display working
remove the GPU and reset the BIOS and hopefully the onboard display will work
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/275580-need-help-new-pc/#findComment-3746529
