Cooling a Toaster
Since my Mobo only has 1x cpu cooler port and 1x 3-pin fan port. I was thinking of getting something like this to have more fans
Multisleeved Molex to 3 x 3-pin 12V Fan Adapter or would I only need the 5V version. I plan on using 2-3 120mm fans depends on the temperatures of my pc. Thanks ^_^
Overkill Chill:
CPU: Intel® Core™ i5-3450 CPU with Hyper 212evo | RAM:  2 x 4 GB DDR3 MoBo: ASRock H61M-DGS R2.0 | PSU: Rosewill PHOTON 750W | GPU: SAPPHIRE DUAL-X R9 280 3GB | Case: Antec One Gaming | Storage: Kingston HyperX 120gb, Seagate 2 TB | OS: Windows 10 | Displays:  Asus VS228H-P, Hp 2009m
https://linustechtips.com/topic/275042-cooling-a-toaster/
Here I was expecting a water cooled toaster guide. :(
To answer your question most fans should run on 5V although you may have some issues. The voltage will depend on how fast you want the fans to run.
You may want to consider getting a fan splitter so you can still control the fans with the motherboard. Link
Quantum Chaos: i7 6850K | 2x Strix 1080Ti SLI | MSI X99 SLI Krait | 32GB Corsair Vengeance LPX | Samsung 970 EVO 500GB | 3TB WD Red RAID 1
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3734359
That depends on your preferred noise level an the type of fans you use.
running all fans at full speed can get really annoying, especially if you use ones that aren't optimized for silence. Also usually only higher quality fans start at 5V.
Probably your best bet is to use the 7V version so your fans don't run at full speed and are actually starting.
Did you know this forum has an unofficial/official Star Citizen group? Head over to our organization's page, numerous forum threads or our LTTC Discord Server to find out more.
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3734487
  • 2 weeks later...
I got the 7v version and plugged it into my powersupply with one of my fans as soon as I start my computer it turns on then off again. Do you know why this would happen?
Overkill Chill:
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3851782
Strange. So they start but then stop again? how long do they run?
Is your fan PWM controlled and has 4 wires?
If yes, then they might not work with 7V.
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3852399
its almost instant then they turn off and when I turn off my computer it spins randomly then stops. No I think my fan has 3 wires and ports.
Overkill Chill:
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3852460
Can you tell me, which fans exactly you're using? If you're not sure take a picture of their label.
Edit: do they work if you plug them directly into your motherboard?
Edited by Napper198
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3852483
I am using the ones that came with my Antec one gaming case. I also bought some extra value fans. I tired plugging it into my mobo I don't remember if it worked, but it wanted me to plug back my old one in.
Overkill Chill:
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3853196
Those fans are not particularly designed for being used at 7V, but some reviewers on newegg state, that theirs are working.
Try plugging in just one fan and see if it runs. Test all other fans individually. If none of them works you probably need to RMA that cable.
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3857796
So it should work If I  get the 12v version, because I don't really care about how loud the fans are. I game with a headset on anyway.
Overkill Chill:
https://linustechtips.com/topic/275042-cooling-a-toaster/#findComment-3859815
