So i recently built 2 pc with eveything similar except 2 different motherboards one being a gigabyte z97 d3h and other z97x gaming g1 wifi bk. One thing i noticed is tat the stress test temp on the z97x gaming g1 wifi bk is higher than that of the z97 d3h. Is there a reason for this? the z97 d3h runs at 58~ while the z97x gaming g1 wifi bk runs at 70
https://linustechtips.com/topic/274744-motherboard-temps/
Did you check that the other MOBO didn't auto overclock the CPU higher? That may be giving off more thermals then
My Build | CPU: Intel Core i7-6700K 4.0GHz Quad-Core | CPU Cooler: Corsair H100i | Motherboard: Asus SABERTOOTH Z170 S ATX LGA1151  | Memory: Crucial Ballistix Sport 16GB DDR4-2400 Memory | Storage: Samsung 850 EVO-Series 120GB & 250GB, Western Digital Caviar Blue 1TB 3.5" 7200RPM, HGST Deskstar NAS 3TB 7200RPM | Video Card: MSI GeForce GTX 970 4GB 100 Million Edition | Case: NZXT H440 (Black/Green) | Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified | OS: Microsoft Windows 10 Pro (64-bit)
https://linustechtips.com/topic/274744-motherboard-temps/#findComment-3730630
How can i check?
see that using the intel Extreme Tuning Utility
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/274744-motherboard-temps/#findComment-3730649
it could be the VRMs
certain model even from the same brand may design the VRMs differently
https://linustechtips.com/topic/274744-motherboard-temps/#findComment-3731254
You mean the motherboard? Is there a way to test for sure
we cant test it
you will have to dig for reviews from some website for the detailed specs
https://linustechtips.com/topic/274744-motherboard-temps/#findComment-3731316
