@Rexchaos
Would help if you actually told us what you need help with because right now we don't know jackshit but this will probably answer your question
http://youtu.be/Cq-zqQiY-OA?t=7m56s
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/274457-help-connecters/#findComment-3726831
Go to your motherboard manual for this
@Rexchaos
I tried that and i still cannot get my computer running. (Power doesnt work? )
post-122363-0-86491900-1419200672_thumb.
post-122363-0-84842300-1419200676_thumb.
post-122363-0-14446400-1419200684_thumb.
https://linustechtips.com/topic/274457-help-connecters/#findComment-3726987
Only the leds won't work if plugged the other way (but you still don't damage anything if you do, it's safe).
It's more likely that you plugged them incorrectly, I know it's a hassle but try re-doing them again; you can use a flat screwdriver to touch both pins at the  same time and start the PC with that.
https://linustechtips.com/topic/274457-help-connecters/#findComment-3727102
Yeah.  FP connectors are really stupid and IMO there has to be a better way to do it, but for now, just consult the manual.  There should be a little tiny arrow on the side of the connector that doesn't have printing that tells you which lead is positive.  Only disadvantage to black FP connectors.  In colored ones, black is always negative.
https://linustechtips.com/topic/274457-help-connecters/#findComment-3727492
