Im thinking on buyin a NAS for my documents and stuff that I have arround, but I just can´t decide what to go for
The Business Storage 2-Bay NAS from seagate on amazon they say that it is Mediocre hardware, buggy software, terrible interface design and nonexistent documentation, there are alot of complains managing your own files and etc etc...
And the Personal Cloud Storage My Book Live from WesternDigital they say that the write and read speeds are terrible slow it takes forever to upload files especially if you have alot to back up, it is slower than an USB 2.0 interface www
 and also I think this solution is really old
so I dont know what to do should I wait for a better solution?? I dont want to spend more than $300 USD 3Tb or 4Tb is fine for me
https://linustechtips.com/topic/27431-best-nas-solution/
Buy a cheap motherboard with at least 2 SATA ports. SATA 2 or SATA 3 means nothing for this.
Same with a CPU, Case, and RAM.
Build a system, install FreeNAS on it.
Buy whatever HDD's you want (1-4TB's are preferred in RAID 1).
Edit: @Goliath002
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: AMD Sempron 145 2.8GHz Single-Core Processor ($29.99 @ Microcenter)
Motherboard: ECS A780LM-M2 Micro ATX AM3 Motherboard ($39.98 @ Outlet PC)
Memory: Crucial Ballistix 2GB (1 x 2GB) DDR3-1333 Memory ($16.90 @ NCIX US)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($119.99 @ Amazon)
Case: Diablotek CPA-7620 (Black) ATX Mid Tower Case ($19.99 @ Microcenter)
Power Supply: Logisys 550W ATX12V Power Supply ($20.24 @ Outlet PC)
Total: $247.09
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-06-18 16:44 EDT-0400)
You can trade out the 3TB for whatever size you want (total) and get another one to put into RAID 1 later.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/27431-best-nas-solution/#findComment-348832
Single drive or Dual drive NAS will almost always have poor performance due to super low end hardware in them (I'm talking about the CPU, RAM, etc.).  Even the home office caliber 4-bay NAS tend to be a little on the slow side.  If you want cheap, build your own file server like Vitalius suggested.  If you're willing to spend a bit more look into some of the smaller SMB NAS devices from companies like Synology or QNAP.  You'll have to supply your own HDDs though.
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
https://linustechtips.com/topic/27431-best-nas-solution/#findComment-349661
That makes it easier to RMA imo.
If you get a 2 drive bay NAS and one dies prematurely (first month of use or so), I can imagine that being a hassle to deal with since you'd buy it as a package deal kinda thing.
https://linustechtips.com/topic/27431-best-nas-solution/#findComment-349877
