Read, i need help with something.
Solved by Quaker,
So will a motherboard go in the bios even if it doesn't support the cpu i want in the bios version it comes with? it supports the cpu at later versions and the cpu is the same socket.
In this case, the motherboard should work without out-of-box support in the BIOS, since the newer A10-6800K is mostly just a speed bump over the earlier 5800K. The boot up screens may show "unknown processor" and/or run at the incorrect speed, etc, until the BIOS is updated, but it should run well enough until then.
