https://linustechtips.com/topic/27343-will-it-work/
Hi. I am building a new computer and since I don't know enough I got my friend to help me pick out some pieces. I have a hard drive and 8GB of RAM already but here is the rest of the pieces.
http://www.amazon.co.uk/gp/product/B0068OI7T8/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A1D873RMPMIV2C
http://www.amazon.co.uk/gp/product/B007C008L2/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=AOT9MO389M5IR
http://www.amazon.co.uk/gp/product/B009RMP14M/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
http://www.amazon.co.uk/gp/product/B008RPZ5SC/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
http://www.amazon.co.uk/gp/product/B009O7YORK/ref=ox_sc_act_title_6?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
http://www.amazon.co.uk/gp/product/B00A1572FK/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
I don't have much money so can't go really spend more but all I really need is confirmation that everything will work and fit right.
Thank you.
Yah it will work but I would probably go with a higher power supply, maybe like 550 to 600 watt just to be on the safe side. Also make sure its a good brand like seasonic or corsair. Other then that it looks good. What is your budget?
https://linustechtips.com/topic/27343-will-it-work/#findComment-347572
Upgrade that powersupply to a CX600.  You will be glad you did that later on...
i5-3570K @4.2ghz | Gigabyte Z77-DS3H | 16GB G. Skill Ripjaw 1600mhz 9-9-9-24 (2x8GB) | 120GB Vertex 3/640GB WD 7200RPM | AMD HD7950 @ 1025mhz | 600W Corsair CS600 | Hyper 212 CPU Cooler | 5x 120mm fans 79cfm | Ultra Defender Case
https://linustechtips.com/topic/27343-will-it-work/#findComment-347600
... if he decide to put another hd7870 inside. But since volcanic islands are on the way, i doubt anyone want hindered performance, heat and noise in their case. Not to mention hd 9000 series will need less power.
https://linustechtips.com/topic/27343-will-it-work/#findComment-347610
It looks solid. I'm not sure if you'll be able to overclock fully with a cx430 though. I'd get a xfx 450w or cx500 to be safe--maybe a cx600 if it's not too much more expensive.
https://linustechtips.com/topic/27343-will-it-work/#findComment-347620
