hey linus community i am using a 4k monitor and have all my settings set to 4k. the only thing is some things look 4k others 1440p and some even 1080p. how do i make them all look 4k.
thanks
wolffangs147
Its when dragons have so much sex that the cpu cant handle it
https://linustechtips.com/topic/273001-resolution-problems/
thanks
wolffangs147
The problem is not all programs, or web elements have been made with 4k in mind, so for example if a website is using low quality images, they will not look 4k
The same with programs, they developer may not have made UI elements that scale to 4k
https://linustechtips.com/topic/273001-resolution-problems/#findComment-3703815
when i was using my pc before all the programs i was using were running at 4k. now some are not
https://linustechtips.com/topic/273001-resolution-problems/#findComment-3703835
What programs and stuff are we talking about that look wrong
https://linustechtips.com/topic/273001-resolution-problems/#findComment-3703870
