Got a z97 Guard Pro from MSI. Peaked in the box because it's my first ever build and holding computer parts. Was really sketchy about the front panel so I checked on the bottom side of the board. Didn't see anything. Bottom right corner it's like 8 pins that's split in half. Really don't know where it is lol
pic
Sorry about the circles. Well anyways, if you need a closer look, I'll try to snap one on my phone
https://linustechtips.com/topic/272176-wheres-the-front-panel-pins/
The front panel bus? Bottom left corner, like always.
 Pic:
Also, don't worry about holding the mobo, as long as you don't touch it with something conductive or wet you'll be alright. Just put in on the box while you admire the beauty.
oh wait what? on most motherboard reviews, i thought i saw them on the bottom right corner
If you're looking at your picture, it would be bottom left. If you are looking at the mobo from its standard view (with the CPU slot facing upwards), you are right, it would be bottom right.
the manual will tell you everything you will need to know about where to plug things in
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
The FP connectors would go to red pins right next to circle on left side. The USB3 port is right next to 24pin, USB2s are somewhere but since they look lot like serial port etc. I can't really point them out. The two top most of left side look like 4pin fan connectors.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
