Hi all,
I bought a Nexus 10 about 2 years ago.  Normal use for the tablet was as follows:
  • Used everyday after work heavily
  • Used on weekends heavily
  • Accompanied me on work trips regularly
Normally I left my tablet turned on and attached to the charger accept for when traveling.  Then I would use it on battery while in airports or in the plane and charge it every night.  I traveled about 50%of the time.
My battery lasted about 1.5 years and then it wouldn't keep it's charge after that and I would need top keep it plugged in at all times if I wanted to use it.
Now I an considering buying a new nexus 9 and I want to extend the battery life down as long as possible.  A few questions come to mind
  1. Should I turnoff my tablet when not in use?
  2. Should I use my tablet while it is puffed in or should I run it on battery?
  3. Should I keep the battery topped of as much as possible or should I let it draw down?
  4. Other ideas?
There is so much conflicting information and opinions out there that it is a bit confusing.  I see that different battery types should be handled differently but I am not sure how I should treat the Li-polymer battery to maximize is life span.
Thanks for any information.
https://linustechtips.com/topic/271600-tablet-battery/
1: Turn off, but not shut down.
2: On battery it will be slightly better.
3: It is best to stay between 30-70%  charge.
4: Don't worry, there isn't anything that will significantly help, just try too not let it overheat (eg. from leaving it on in a car in the sun). Nothing will make a very significant impact on life (besides killing it like with the heat eg.)
https://linustechtips.com/topic/271600-tablet-battery/#findComment-3684821
That guy is right
Cold will drain your battery faster but will not affect when your battery falls off the proverbial cliff of not lasting long.
https://linustechtips.com/topic/271600-tablet-battery/#findComment-3688964
