Quick CPU Motherboard Questions
Go to solution Solved by Laputacake,
MSI Z97 G55 SLI
This winter I'm going to be upgrading from my old school Phenom x6 1075t to a Xeon E3 1231V3, and had picked a handful of motherboards to run along side it.
I know the Xeon supports ecc memory, but correct me if i am wrong but it doesn't REQUIRE it correct?
Anyway, assuming that here's a couple motherboards I was going to choose between, please feel free to correct me if they are missing some sort of hidden requirement.
If you have any other mobo suggestions feel free to post em as well, what i need is support for 2 graphics cards (3 Optimally so i can run my 8800gtx as a physx chip) and a sound card optimally (but not required). As well as built in optical port.
Gigabyte GA Z97X         http://www.newegg.com/Product/Product.aspx?Item=N82E16813128723
MSI Z97  Gaming 7        http://www.newegg.com/Product/Product.aspx?Item=N82E16813130768
Gigabyte GA-Z97X         http://www.newegg.com/Product/Product.aspx?Item=N82E16813128707
ASRock Z97 Extreme4   http://www.newegg.com/Product/Product.aspx?Item=N82E16813157503
ASRock Z97 Pro4           http://www.newegg.com/Product/Product.aspx?Item=N82E16813157507
Budget is <$180 USD
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/271506-quick-cpu-motherboard-questions/
Budget is <$180 USD
It should depend on the mobo and if you are not buying specialized server boards, I think it should support both normal and ecc ram
| --- My Stuff --- |
Computer: Apple Late-2008 Macbook Pro ; -Haguro- build: http://linustechtips.com/main/topic/296613-wip-project-haguro-x99-hackintosh-workstation/|
Mobile Devices: Apple 32GB 1st gen Ipad Mini ; Apple 16GB Iphone 5s ; Apple Ipod Classic 80Gb 5th Gen ; Apple Ipod Classic 120Gb 6th Gen ; Apple Ipod Classic 160Gb 7th Gen ; Apple Ipod Nano 16Gb 6th Gen
Xeon's dont require ECC memory but consumer grade mobos don't also support it.. i would suggest Gigabyte or Asus motherboards personally also maybe have a look at an i7 over a xeon unless you think a xeon will be better for your needs
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
For the price and for what i do it's the best option. Need good single core performance for gaming, and the capacity to keep up with the heavy multitasking i run. I looked at a couple i7 chips, but the cost of the newer mobo and higher cost to get similar performance is just too high. I'm still a student and can only allocate so much towards this kind of stuff ye'know? xD
yea makes sense im pree much in the same situation, the mobo won't affect "performance" as such linus did a video about this and xeons can be a great choice im probably going with one next time. i was just suggesting the i7 so you have the ability to oc and what not :3
Yea i would have like the capacity to overclock and some of the gaming features that the i7 has over the Xeons, but when it comes down to it we all gotta make compromises
MSI Z97 G55 SLI
Wonderful suggestion, can't believe i didnt see that before. Might have to do a bit of hunting to find it in stock nearby but much appreciated mate!
