I had same weird problem when i overclocked my Fx-8350 to 5.1Ghz
I think that my GTX 650 just bottlenecks.
please post your system specs, did you also up your voltage as well?
Amd Athlon ii x4 640 Overclocked to 3.6 Ghz 1.44V
Hd 3300(Onboard) Overclocked to 1 Ghz 1.32V Stock(1.2 V)
4X2 Gb Ram 1600 Mhz 1.65V
790 GX chipset.
I had to sold my Gpu to buy a HDD the onboard solution was enough to play games but after reformatting it was not performing well.
is the extra 50mhz really going to do much anyways? can you try clocking higher?
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
GPU is bumped up 300Mhz And Cpu 600Mhz.
I meant to say when I overclocked it more the results are decreased.
But will try to get 1.05Ghz
okay, also look at your temps, load, and see how much ram is being used
not sure if this will help but most of the cases when you overclock you dont increase power limit and when gpu tries to use power drivers will block it and tada you will experience a bottleneck if increase my gpu speed to 950 without increasing power limit i get lesser fps in games and crashes in demanding stuff(only in heaven engine so far)
http://i.imgur.com/FUNub2S.jpg
Thanks for your reply But I have a Onboard GPU and that od HD3000 series.
