So i want to do custom loop in enthoo primo and i was thinking about 480 monsta in push-.pull in the bottom and a x radiator in top (360 or 480).Can somebody help with how thick radiator can i fit in without interference with MOBO.
Also i will do push-pull.
Sorry for bad english, im from Slovenia. :D
Thanks in advance.
https://linustechtips.com/topic/270064-enthoo-primo-radiator-help/
Enthoo Primo FAQ's taking from another forum: vrforums.com
- The case has a clearance of 70mm for mounting a radiator in the roof. The mounts are offset by ~54mm so installing a 60mm (120mm series) radiator in push pull should not be an issue. As long as you do not have anything taller than 53mm on the motherboard (including ram), you can even install a 480mm monsta radiator in push pull. The X79 Dark, and G-Skill ram CAN be used with a monsta rad in push pull.
Bert & Ernie before squirting spermie.
