FreeNAS Encryption Assistance - Mount USB
Question: Have you asked this question on the FreeNAS forums yet? They are here: forums.freenas.org I would ask under: Help & Support > Storage.
I don't know much about Encryption and I don't know of a way to fix a "mangled root partition", which I'd imagine is a requirement to mounting the partitions.
They might. If you are screwed however, they will probably be very "Well, you should've known better." They can be harsh when it comes to basic things, though not always.
I did go on their forums as well, but before they could respond, I got it to work . It's hard to explain the stress off of my shoulders now. I don't even want to talk about how much anime I could have lost.
For reference: I found a utility called UFS Explorer which allowed me to browse the remaining intact files on my usb drive. From there, I followed suggestions from past freenas forum postings to find the .key file on the fourth partition under /geli. Once copied, it was a simple matter to replace the same location on my new usb with the files I recovered.
Moral of the story: Make backups and recovery files for everything before you go changing settings.
