Rubbing alchohol replacement?
Go to solution Solved by ImBleu,
Use coffee filters instead because they leave no paper residue compared to toilet paper.
But if coffee filters aren't available, kitchen roll will work well enough, I used only a few drops of water (don't overdo it) and kitchen roll, worked good enough that my i5-4670k worked around the same as it did prior to removing the CPU cooler.
honestly just water and a MICROFIBRE cloth works - did in my case at least. You could always find a woman and ask if they have nail varnish / polish remover too.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
Pure alcohol is best. The reason being that almost everything else will leave some residue behind. Nail polish is fine though as far as I know.
Never use anything like vodka or stuff like that. It will look clean but won't be.
A microfiber cloth might even be able to clean your cpu without any alcohol. At least better than some half Ass liquid for cleaning.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
Microfiber*
MURICA
No but seriously, water and toilet paper/microfiber cloth should work fine, just make sure it's [CPU] completely dry.
So, water and toilet paper is fine as long as I make sure the CPU is completely dry?
In theory it sounds like it'll work, and CoolBlueKidd says it worked for him, so I don't see why it wouldn't work.
Just don't put too much water, a tiny amount will likely be fine. And don't rub the shit out of your CPU with the toilet paper or else it'll break into very little pieces; the toilet paper, of course.
But--- if you want to be sure about it, just wait until you can get some alcohol.
RIP in pepperonis m8s
Microfiber*
MURICA
Ok, apparently you can use kitchen roll (less dust than toilet roll) to clean it off without any liquid. Just keep on rubbing. Should this be fine as long as I be careful with any parts of it falling off?
Dosent really matter that much, the pc im doing it on is only a test one anyways. I'll just put a tiny bit of water onto a bit of kitchen roll (apparently less dusty) and rub, leave to dry and expelliarmus?
That or microfiber cloth. Both work well.
I don't have any of that, I don't think my town would either. I can't even find rubbing alcohol in it, only white spirit, thus this thread was born
Exactly the answer I wanted. Thanks :D
I just use a dry coffee filter. It works like a dream
:D
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
Or a lint free cloth.
All this nonsense when you can take a paper towel and it works just fucking fine jesus...
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
Would a wash flannel be OK?
That thing will leave lint residue. Unless it's like brand new and very lightly used.
no....
Ok, I've cleaned it all (including the Heatsink and the Heatsink's fan), and I'm going to leave it overnight on a bit of kitchen roll. Then, in the morning, I'm going to install it, put on the MX-2, put on the Heatsink, put on the fan and voila! ?
Automotive brake cleaner. That what i use. Spray some on a cloth then wipe the thermal paste off.
PC 1 Specs (New) :
Corsair 450D | Intel 4770K | Asus Sabertooth Z97 | 16GB Corsair Vengeance @1600Mhz | Asus STRIX GTX 970 SLI | Samsung 840 EVO 250GB | 2 WD Black 500GB RAID 0 | WD Red 3TB | Corsair AX860 | Corsair H110 | 4 Corsair 140mm LED & 1 120mm Fans
PC 2 Specs (Old) :
Corsair 650D | AMD Phenom II X6 1100T | Asus Crosshair IV Formula | 4GB Corsair XMS3 @1600Mhz | Crossfire HD6970's | Asus Essence STX | OCZ Agility 3 240GB| WD Blue 250GB | WD Green 640GB | XFX850PRO | Corsair H100i
Peripherals :
BenQ 2420T | Packard Bell Viseo 220DX | Corsair K70 | Corsair M65 | Beyerdynamic DT880 Premium | Sennheiser PC360 | Bang & Olufsen Beovox X25's
