Best choice for overclocking
Go to solution Solved by Dabombinable,
Decided to install the Freezer 7 only to find that idle temps were 10oC higher, and the maximum stable overclock was lowered to 3.7GHz. So it seems I should have stuck with the original cooler.
I recently bought a Freezer 7 Pro Rev.2 for use with my i5 4440, but once I started overclocking my older core 2 duo and saw the temps (73oC full load with case side on) I was unable to decide whether to keep using the P4 cooler on it (solid aluminum block-type) or to use my new cooler instead. Which one should I use as I don't want to have to drop the OC so that the temps lower.
P4 cooler (deepcool but of unknown model edit-its a winner s915):   http://www.deepcool.com/product/cpucooler/2013-12/7_206.shtml and photos          post-155575-0-31479800-1418454188_thumb.           post-155575-0-08599400-1418454237_thumb.
Freezer 7: http://www.arctic.ac/worldwide_en/freezer-7-pro-rev-2.html and photo - post-155575-0-95625300-1418454417_thumb.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/269264-best-choice-for-overclocking/
Which system to do value more? Use the better cooled on that one.
I'm not as concerned about the i5 (I just wanted something quieter-and the i5 can't OC so it won't benefit as much). My main problem is which one is better, as I don't want to waste any arctic silver on the freezer 7 if it doesn't actually work as well as the manufacturer states.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
