will this build work?
Solved by OhhTee,
Why not grab the GTX 970 instead of the R9 290x?
I would also replace the RM with a 750W G2 EVGA, it's a better PSU.
You could also grab an mx100 256 GB instead of that Intel 530 with another $20 or so.
Possibly change the h100i too if you're planning on using Windows 8.1. I heard there are software issues for the corsair link and also mounting issues.
